ecm numbers
Old 09-06-2016, 06:32 PM
diggerod's Avatar
Default ecm numbers
I'm need to replace my ecm and was wondering if anybody could confirm if the numbers on the new will work. They are from left to right on the box, 1st one is ERR7377 80754A Date Code is 0197. and the old ecm numbers are ERR6355 80630A date code 3295. both ecm are out of a 97'.
Old 09-07-2016, 06:16 PM
ihscouts's Avatar
The ERR7377 is for AEL and the ERR6355 is for a 97 without AEL. So basically pretty easy answer, you have either or controlling your motor. If you have an early 97 its doesn't have it, later 97 does. Round charcoal can or square on it side.
You can use the AEL ECU on a non-AEL system, it might or might not set the CEL. If you use the non-AEL ECU on an AEL truck it won't run well.
Old 09-07-2016, 06:49 PM
diggerod's Avatar
Thanks for the quick reply ihscouts, I think the one that was in it was the wrong one. The charcoal canister sits right in front of the ecm correct?
Old 09-07-2016, 07:14 PM
ihscouts's Avatar
Yep and it's either laying on it's side and square for AEL or upright and round for non-AEL.
Old 09-07-2016, 07:16 PM
diggerod's Avatar
Gotcha, so mine is upright and round. Ok then, I'll look around for another ecm to match. Thanks again
Old 09-07-2016, 07:24 PM
diggerod's Avatar
So, the one for an AEL will work thou? I run this off road only, what will happen if it doesn't set the cel?
Old 09-07-2016, 07:30 PM
ihscouts's Avatar
Yep, it'll work just fine and have newer code. You might want to get the alarm module that mates with it. I say that because sometimes it works and sometimes it doesn't. I had a buddy with a 97 with AEL and he had no problem with the newer ECU and his original alarm module. I, on the other hand needed the alarm box to go with the AEL ECU and I can only guess because mine isn't AEL. Just a guess. It's about a 50/50 shot.
Old 09-07-2016, 07:40 PM
diggerod's Avatar
ok, thanks again!!
Old 09-07-2016, 07:48 PM
ihscouts's Avatar
Post back what your results are and if you run into anything unusual.
Old 10-12-2016, 04:15 PM
diggerod's Avatar
Well I found an ecu that matched my #'s the 6355 one and installed it yesterday and it won't start. Just my luck, Do you guys think it needs flashed maybe?
Quick Reply: ecm numbers
