Effective Engine Improvements?
Seeing as your truck has high mileage, unless you know for sure from the service history, it wouldn't be a bad time to take the next step and replace the cam, lifters and timing chain. But, I would certainly understand if you chose not to do those items for a variety of reasons. You've paid a viscous premium already for your truck.
Good luck.
Good luck.
Good point Paul. I do at least want to increase reliability as well. Do you have a ballpark idea of parts cost?
I was led to believe there's power to be had from reading things like this:
From "An heroic engine":
"Why did the “Rover” V8 live such a long life? Unlike the A-series engine, which was successful despite its shortcomings, the ex-Buick unit did not really have any. It was light, it was compact, it was powerful – and most importantly, it was exceptionally under stressed, which meant it had an almost infinite potential for tuning."
Also, toddco sells a modified Land Rover 5.0HO engine with 320HP 340 FTLBS torque.
From reading previous threads it's pretty clear there's little to be gained from external upgrades like exhaust and intake so I thought "why not internal?" But if it's already reached much of it's potential like you're saying then that's ok.
Big engines like that are fine in a sports car like a TVR or a Morgan where you want insane speeds. As far as out trucks are concerned, they're rolling brick s**thouses and as such, higher power only brings on a degree of fragility that I don't think is really worth it. Stick to the basics and you'll be happier and safer with a more reliable engine.
Unlike Detroit iron, which is built with the same chassis for multiple versions, each with slightly larger engine; the Disco is built for outdoor fun, not speed. It's no BMW for handling, has high center of gravity, etc. Increased HP will fail other components not rated for such (tranny, transfer case, prop shafts). So while it would be possible to make a Disco go faster in a straight line, that field of sport is already dominated by others.
IMHO Paul is right, you have paid the tuition for the College of Hard Knocks and should be expecting that sheepskin just any day now. Reliability issues like water pump and radiator and hoses, then get to know your vehicle before you decide on any more investment. Would advise when complete with this project to rent/borrow (from auto parts store) a coolant pressure tester and a compression tester, so you can check to be sure (a) your work is sound (why would it not be with dozens of forum members looking over your shoulder?); and (B) something like piston rings is not waiting to grab you.
BTW - enough wrenching and paper grading - off to a meal out, and it can not be on the same route with an auto parts or tool store....
on
I AGREE, IF YOU JUICE IT, IT WILL JUST BREAK EASIER AND MORE FREQUENTLY. And tear up more stuff if not flipping it and killing yourself. It ain't no racetruck.
I know mine has gotten more resonsive every time I accomplish something. Like new plugs and good 8mm spark plug wires help a lot. O2 sensors that are good also help tremendously and increase mpg.
Fixing your HG will help tremendously. New hoses, serp belt, things that avoid a major breakdown are what you need to focus on.
And always using premiun gas. My son put low octane in mine and it ran terribly. 93 octane made a hell of a difference.
