Electrical problem
Old Nov 21, 2011 | 04:48 AM
Sounds like problem with ignition switch to me.
Old Nov 21, 2011 | 09:36 AM
txt1's Avatar
Ok so was outside looking at the landy and the ignition fuse was blown but stell has juse going to it but the 100 amp has no power i am not good at electrical stuff
Old Nov 21, 2011 | 09:46 AM
If no volts between 100 amp fues and metal frame of truck or negative (-) battery terminal, check wire from plus battery terminal (+) that runs to front corner of fuse box. Very short, less than 2 feet long. Connector at battery terminal end can get corroded or come apart. That wire carrys battery volts to the 100 amp main fuse.
Old Nov 21, 2011 | 10:31 AM
Danny Lee 97 Disco's Avatar
Just keep in mind that 99.99% of the time, the problem is not merely that the fuse blew, rather the question is why did the fuse blow?
A blown fuse acted properly by blowing when the current exceeded the rated limit.
A fractured or corroded fuse is different than a blown (melted) fuse element.
If you replace the fuse and it blows again, you need to resolve the cause, since the blown fuse is an effect.
Cause versus effect. Resolve the cause instead of merely addressing the effect. A fuse is a safeguard to prevent bigger problems.
Old Nov 21, 2011 | 11:38 AM
And when all else fails, build charcoal fire directly under oil pan drain, open drain to provided steady drip, and continue with ceremony to honor the Rover gods.....
Old Nov 21, 2011 | 11:44 AM
txt1's Avatar
well i guess this is gods way of showing me that you my have what you want but its not. what we need. i wood love to have it but the wife says it must go. thats ok just found ihc 3/4 ton 4x4 for 800 theres my new play toy at lest i can fix it.
Old Nov 21, 2011 | 01:19 PM
So park the Rover in a nice open space, wrap the blown fuse in aluminum foil or copper strands and put it back in, allow some gas to leak from it, stand back a good distance and send it on to the Rover Gods in a blaze of glory!!!
DiscoBlanco's Avatar
You're getting rid of it? I will buy it off you for $200.
Old Nov 21, 2011 | 01:24 PM
Mick Jagger, you get what you need - Bing Videos
You sure you want an IH they been out of production for so long, maybe you would be better off with a Chevy.
Old Nov 21, 2011 | 01:54 PM
txt1's Avatar
Dont want to but may havr too if i cant get this dam thing too work
