emergency issue with steering wheel
Aside from key being locked in the god dam ignition, i think i may have broken the steering wheel. Was trying to turn it back in forth in an effort to remove the key, something snaped and as a result the steering wheel now moves freely in any direction. Can now be spun sevenfold! It feels as if it no longer connected to the steering system. Is there a quick do it yourself adjustment that can be done to fix the issue so i can steer again? Im at work and if i cannot get it working my rig will probally be towed! Please help. Useful detailed replies please!!!
My camera is broken at the moment so ill have to rely on detailed description. As of tbis moment i had a work associate look at the rig and he noted that the long silver steering shaft (long steel shaft with a special plastic tarp material over it, one end connects directly into the stering gearbox) is missing a bolt down near where the shaft connects to the gearbox. But i dont ever remember there being a bolt there in the first place. Also i do believe that when the steering wheel is turned the shaft does not turn with it like it should.
[QUOTE=antichrist;252864]Have you looked at the linkage in the engine compartment? Sounds like one of the u-joints may be slipping.
Short of the steering wheel coming off the shaft splines, I can't think of anything in the cabin that would allow it to spin endlessly.
U-joint??? Are you refering to the front driveshaft u-joint? Or are there u-joints in the steering system? And yes ive looked in the engine compartment. As mentioned before when you turn the steering wheel it will spin without any resistence, and take note that when turrning the steering wheel, the long steering shaft in the engine compartment does not rotate the least.
on
I just went out and looked at mine (never paid much attention to it before now).
Unsnap that heat shield and you can see the entire linkage. There is an upper and a lower univerdal joint just like Tom reffered to. You may not realize they are universal joints, but they are. There is also a splined area in the center. That is the linkage from the steering wheel to the steering box. If the long steering shaft ain't turning, that is your main problem, try to figure out why since you can see it and we cannot.
Next time, try finesse when fooling with the key being stuck. Whatever snapped should be obvious. Let us know the results.
I learn so much from these horror stories. Brute force is not always the best route when encountering problems with these old Rovers. Slow down, try the easy approach, coax it a little, beg it if you have to, then if all else fails, pound the hell out of it.
Take a good look at it and see where the "disconnect", difuggulty, problem, or whatever you want to call it is. If the
At any rate after alittle help from a work mate and rovrsnorth i was able to identify the problem and temporarily fix it! Turns out one of the bolts in the lower shaft u-joint came out some how and as a result i lost the ability to steer. As it turns out i happen to have afew extra brand new rear driveshaft and oil pan bolts in my tool box, inserted it in and it seems to fit perfectly. Looks almost identical to the other u-joint bolts to! I tightened it up and made sure the wheels were aligjned properly with the steering wheel. Have not test drove yet but i started the ignition and turned the wheels afew times - so far so good. Im alittle nervious about driving being as unsure as im but its another risk i take.
Sounds like a fault in the Key Barrel Switch, Transmission Range Selector Switch or the Ignition Key Lock Solenoid.
If they aren't working correctly you can't remove the key as the Key Lock Solenoid (K191) doesn't get disabled.
If I recall correctly the steering shaft u-joint bolts are 8mm. Be sure they are correct, you don't want a repeat while driving down the road.
Vinndego
01-06-2014 11:14 AM
Classklown90
10-02-2010 10:32 AM
