Engine dies after a short drive
Old 06-30-2012, 12:56 PM
marjac's Avatar
Default Engine dies after a short drive
Can i get a word of advise. 96D1 w 121k miles. After driving a short distance the engine will idle down and shut down if stopped. Any suggestions. I an thinking thermostat or mass air flow unit. Stop lights are a pain! Thanks for the word!
Old 06-30-2012, 01:23 PM
Won't be coolant thermostat. Coolant temp sensor faults usually make higher (richer fuel mix) idle. Could be IACV needs to be cleaned with carb cleaner, when you remove it do not adjust the pintle, just clean with spray.
Old 06-30-2012, 01:34 PM
EricTyrrell's Avatar
Yes, I've had IACV cause this before.
Old 06-30-2012, 01:36 PM
marjac's Avatar
Thanks for the quick reply. I will give it a shot. And let you know the outcome!
Old 06-30-2012, 02:37 PM
marjac's Avatar
Ok after an hour in my rave manual where an what is the IACV. You cannot teach stupid but the ignorant can learn!
Old 06-30-2012, 02:40 PM
Old 06-30-2012, 02:46 PM
Idle Air Control Valve page 277 of 873 in the workshop manual, and 295. You remove it, squirt well with carb cleaner, and use some carb cleaner on the bore it came out of. Don't mechanically adjust it.
Old 06-30-2012, 03:01 PM
marjac's Avatar
Old 06-30-2012, 03:03 PM
marjac's Avatar
Thanks so much i am on it! I will let you know!
Old 06-30-2012, 05:43 PM
marjac's Avatar
Cleaned the IACV and everything else I could get to. Running much better. Thanks again for your help and guidence.
Quick Reply: Engine dies after a short drive
