Engine ECU
Old Oct 6, 2012 | 12:56 PM
b63215b's Avatar
Default Engine ECU
Can someone lead me in the correct direction for the Engine ECU, its location (preferably by picture) and specific directions as to where it is at along with what I need to remove to get to it. It would be appreciated #pullinghairout
Josh
Old Oct 6, 2012 | 01:35 PM
b63215b's Avatar
Default Nevermind
I found and the outside of the case if corroded but the inside contacted look normal or fine. How can I tell if it is broke or not working properly?
I found one on ebay for $200 part number MKC104420 Gem8.
Does that sound like a fair price?
Old Oct 6, 2012 | 01:47 PM
Jason Andrew's Avatar
Where did you locate the ECU? I'm having the same problem. Any chance you can send a photograph of where it's at?
Old Oct 6, 2012 | 02:03 PM
Bkreutz's Avatar
Does this help? It comes from the RAVE manual, you would find it useful. RAVE
File Type: pdf
Old Oct 6, 2012 | 02:09 PM
b63215b's Avatar
Default Ecu
It is on the passenger side under the hood under the windshield wiper cowl. There is a black cover next to the emissions box. There are 2 screws on the inside of the fender mount and 2 plastic pins on the bottom. Mine was severely corroded on the outside the inside did not look to bad.
Old Oct 6, 2012 | 02:38 PM
bcbp's Avatar
Out of curiosity what issues are you having that lead you to believe you need a new ecu?
Old Oct 6, 2012 | 02:42 PM
b63215b's Avatar
Occasion stalling, poor idle response, poor engine response in general. Started during a damp day while raining where it would not start. Intermittent not working of wipers, windows, sun roofs, etc. Now it is not starting period. In other posts it was suggested to look at it, and I have a massive rotted section of the inner fender well right where the ECU mounts. Likely could be a cause
Do you have any suggestions about what it could be, or what symptoms would I notice if the ECU was bad?
Josh
Old Oct 6, 2012 | 02:47 PM
bcbp's Avatar
I'm sorry I do not, I'm new to rovers. I'm having a high idle issue that I think an ecu reset will resolve. I'm sure a few members who know their stuff will chime in, these electrical gremlins are a PITA. Good luck.
Old Oct 6, 2012 | 04:07 PM
Leave the ECU alone, tell us about the truck, fault code numbers, mileage, when it was last tuned along with new 8 mm silicone wires and have you ever cleaned the t/body and the IAC?
Paul Grant
Aug 10, 2014 12:29 PM
BigSkyRover
Oct 1, 2012 12:11 PM
gipson
Oct 27, 2010 03:49 PM
SJT
May 15, 2008 08:22 PM
