engine missfire
engine missfire
Hi, I have a 1996 discovery TDI diesel. It has a missfire on no4 cylinder. It has injection , has compression etc. The injector has a wire off it which i gather is the reference for injection. the circuit is good through the sensor. the engine check light does not come on but if i disconnect the wire the engine runs the same but the check light comes on. the smoke out of the exhaust is gray/white. I have checked under the rocker cover and the top end all appears to be ok. Any help with this would be much appreciated.
Location: Oklahoma; where the winds come rolling down the plains.
on
Sounds like an air leak. Have you bled your system? Start at the fuel injection pump and work towards each injector. Bleed the tank side of the pump first, then the injector side and up to each injector. The seals dry-rot and cause air leaks mostly from moisture. Make sure you clean each injector fitting real good, and then re-seal. Sometimes they leak at the top of the fitting where the tube enters, because of debris.
Thanks for the advise. I checked with the local dealer and he said my compression reading of no4 was good (240psi), which to me seemed too low, i checked the others 400, 390, 400 psi. so i removed the head. no 4 piston is about 1/8 inch lower than no1. suspect bent rod. may have got water in it and had a lock up?. will pull off sump and remove piston and check and let you know,
IDAHODISCO
09-17-2009 08:54 PM
