Engine mounts
Old Mar 14, 2022 | 08:28 AM
WaltNYC's Avatar
Default Engine mounts
What would you install on a Discovery 1 (1997).
a- Land Rover ANR2805
b- Jaguar JLM1010
c- something else
Old Mar 14, 2022 | 10:04 AM
Best4x4's Avatar
I did the Jag mounts. Cut the stud length to match the LR & tossed em on.
Old Mar 14, 2022 | 11:47 AM
stillruns's Avatar
Yea, but why not just get the LR and avoid having to cut? Wouldn't they be a direct replacement?
How difficult of a job is this by the way?
Old Mar 14, 2022 | 01:52 PM
Best4x4's Avatar
Jaguar engine mounts are made for a V12 and supposed to be basically a HD version when used in a LR. Cutting the studs off took no time at all. The job itself isn't that bad but the original nuts can be a PITA to remove especially the driver's side.
Old Mar 14, 2022 | 02:19 PM
ononomos's Avatar
I used All-Makes ones and they’re okay. Except for the fact that I can’t get the bolt on one of the studs completely because the stud keeps rotating inside the rubber bushing. Ugh! So if there’s a mount with a straight-thru bolt, get that one.
I heard tough HD engine mounts are a bad idea because they don’t dampen the engine’s shaking and end up doing the opposite of what they’re for.
Old Mar 14, 2022 | 03:22 PM
hrhoward's Avatar
Put the Jag mounts in a few years ago, '19, when I had the engine out. Early '18, I p
ut in some of the "correct" ones by one of the cheapy brands. Kinda garbage. Jacked one side up at a time to install those.
When engine was out, I did notice that things didn't quite line up on the engine & frame. Ended up having to loosen the transfer box mounting brackets at the frame. They are slotted. Gently scooted the transfer/trans/engine assy. with a 10 lb sledge hammer until motor mounts line up.
Picture is of the cheapy mounts that were on there for only a year-ish.
Old Mar 14, 2022 | 05:11 PM
Best4x4's Avatar
I haven't ever noticed any dampening differences with the Jag vs OEM stuff. I have however noticed when the OEM ones wear out you've got a good chance of the engine sagging over time.
I went with the Jaguar stuff because I was never sent the prototype engine mounts from Safarigard... I was tired of my fan blade exploding, and the lower shroud going out along with it (those shrouds are $$$ and getting harder to come by). Jag mounts have been on 3k so far and zero issues.
Old Mar 15, 2022 | 04:01 PM
CbIdrive's Avatar
After ripping my second set apart on the torque side engine and trans mounts, I took the third set and cut the studs off the new drivers side mount and dropped a grade 8 bolt through it, tightened it just over finger tight and locked it with a jam nut. Never broke again. When I pulled that motor to install in a different build the compression side mount was completely squeezed out and useless.
I have a build going on right now and have a set of the Proud Rhino HD mounts (Lucky8llc) to go in. I know the vibration will be increased, but I never want to have to get off the mtn with a ratchet strap holding my engine down again.
Old Mar 17, 2022 | 12:50 PM
WaltNYC's Avatar
Thanks to all. One more question... can this be done without disconnecting the exhaust manifolds?
Old Mar 17, 2022 | 06:09 PM
Best4x4's Avatar
Yep you can do it without messing with the exhaust. I got the driver's side mount out easy & passenger side I just unbolted entire thing from the block along with the rubber mount.
