Engine noise, oil light
If it did, when you changed the oil filter, did you make sure that the old black rubber seal came off with the old filter? If you have the old filter, look and see. If it's missing from the old filter, it could still be on the truck, and causing the leak. Simple fix, just take off the new filter, peel off the old seal, and put the new filter back on.
If that's not the problem, where is the leak coming from?
LADEROUTE
11-11-2014 10:59 AM
