Engine oil capacity for '94 LR Disco?
Like these?:
http://www.roverparts.com/Parts/MWC9134.cfm
You can also try the nuts an bolts section at home depot/ lowes. They have a lot of random stuff there.
Yes, those! I will probably make a trip to Lowes sometime soon
Here's what my door currently looks like. As you can see, I have barely any of those panel studs right now
http://i51.tinypic.com/2wmf9t0.jpg
Hope you did not use Power Steering Fluid.....................
I am not sure about the 1994 but Disco I's use ATF in the Power Steering Syustem, not power steering fluid!!!!
If ou cannot locate the plastic parts locally try a body shop/interior place. They may give you a few if you are cute and sweet to them.
If you want to post replies, make them accurate so new people won't do something wrong, like follow your information.
I would suggest you stop topping off fluid and follow my major service list at the top of this section, changing all fluids as well as the rest of the list.
If you have any questions, PM me your number and I'll call you.
Yeah I was looking at the list the other day, and while I'd like to do all of that, time and money are a little low right now
You're why I rarely come around here any more.
FWIW, I filled my power steering reservoir with ATF after we swapped my engine and HOLY SH*T! My power steering works fine!
And here's the kicker, it doesn't even leak!
