Engine oil in expansion tank
Old Nov 4, 2018 | 07:23 PM
bordonladdie's Avatar
3rd Gear
Default Engine oil in expansion tank
My 1997 Disco 1, was working fine tonight. Made a stop and had to get a jump start. A few miles afterwards, coolant gauge shot up.,and when I looked under the bonnet most of my engine oil was leaking out of the expansion tank.
Could this be anything other than a leaking head gasket?
Old Nov 4, 2018 | 07:27 PM
aemnky606's Avatar
Blown head gaskets. Time to replace them.
Old Nov 4, 2018 | 11:30 PM
Icannap1's Avatar
Couldn't it also be possible for the oil cooler connection in the radiator rupture and cause oil to be in the coolant?
Old Nov 5, 2018 | 09:04 AM
hrhoward's Avatar
My money would be on head gaskets.
Old Nov 7, 2018 | 04:11 PM
Llamasayswhat's Avatar
I don't think you would be pouring oil out of your expansion tank from head gaskets.. how much was actually coming out? is there coolant in your oil? How about your transmission oil?
Old Nov 7, 2018 | 07:40 PM
ihscouts's Avatar
Apparently you haven't had a head gasket fail yet...... Your time will come.
Check the oil dipstick, see if it's a chocolate milk shake color. If it is its head gasket failure. Just by the spike in temp it's pretty telling.
Old Nov 7, 2018 | 09:28 PM
3rd Gear
Thanks guys, Actually, it was a blown cylinder head gasket. There were no signs of coolant in the oil , but I have changed the oil, anyway cleaned most of the sludge from the system, Fitted my spare radiator. Now the bugger would not start. I am wondering if I had pinched the gasket on assembly, as I can hear a compression leak on turnover.
Old Nov 8, 2018 | 07:11 AM
WaltNYC's Avatar
Pinching that gasket would be a real trick if you used the proper torque technique for the head bolts and did so in the prescribed sequence.
This may sound silly, but check your #8 spark plug. Some spark plug sockets are too large to fit past the exhaust manifold and the spark plug gets partially crossed and not set all the way in.
Old Nov 9, 2018 | 01:47 PM
3rd Gear
Perhaps from the beginning, I should have stated that my Disco carries a 300 TDI Diesel Engine.
Old Nov 9, 2018 | 02:15 PM
WaltNYC's Avatar
ha ha ha.... yeah, that would help!!!! ha ha ha LOL
