Engine runs rough about 2k RPM
Old Feb 14, 2014 | 10:54 PM
  #61
green-lantern's Avatar
Originally Posted by oljohnboy
Dont know if this helps, I have the 4.0 and I had the same issue with high idle and running like crap. The ECU was bad. It worked but the section that controls the idle had water damage. Check the pins on your ecu and if any show corrosion you might want to get that checked.
Thanks John, I've been thinking about the ECU lately because this is my 2nd engine and I remember an issue like this before with the other one. Just not as bad.
Old Feb 15, 2014 | 09:07 AM
  #62
DiscoJag's Avatar
Have you ever had a valve job ? Head gasket ? Just askin'. I had a sticky valve and it caused a miss at highway speed.
Old Feb 15, 2014 | 06:49 PM
  #63
I don't think any work has been done with this engine. I think I found the problem though.
I did a compression test today, they were anyway from 120-140 something but one had about 230 psi. It was full of fuel. Looks like it is a bad injector that must be hanging open. I have a set off my old engine but I'm thinking of ordering some injectors on line.
Old Feb 15, 2014 | 07:51 PM
  #64
TOM R's Avatar
Just swap the 1 with what you have see if it helps
Old Feb 16, 2014 | 12:17 PM
  #65
yeah that's the plan now. I unplugged the injector and ran it for a min and pulled the plug, it was wet. It must be hung open.
Old Feb 17, 2014 | 09:23 AM
  #66
Got the injector swapped and it runs better but still has the vibration :/
stupid land rover!
Old Feb 17, 2014 | 10:28 AM
  #67
TOM R's Avatar
You mean like we replaced my wires for 1 bad one and end up with a bad coil for another cylinder
Old Feb 25, 2014 | 07:53 AM
  #68
Well it overheated coming home from work the other day. I put about a gallon of coolant in it and drove it 3-4 times with no issues but it started running bad yesterday under 2k RPM's and when I pulled in to my parents driveway it started to get hot again. I ended up putting about a gallon in again. When I left my parents house I drove up their steep driveway and it ran perfect and strong (witch was incouraging) but now it seems to run a bit funny under 2k but fine at 2k and above.
I have a radiator ordered, should be in today or tomorrow. I just hope I don't have head gasket issues now. No smoke or steam coming out of the exhaust, no water in the oil though.
Old Mar 4, 2014 | 09:19 AM
  #69
Well I think I have a busted head gasket. The cooling system is over pressurizing. It wants to leak out one of the bottom hoses and around the cap.
I'm not positive but it's looking pretty grim. I've worked all weekend so I haven't had much time to mess with it.
Old Mar 4, 2014 | 11:56 AM
  #70
TOM R's Avatar
Head job, or cracked block seriously think you are joining the hg club
