Engine runs rough about 2k RPM
Old Feb 7, 2014 | 08:01 PM
  #51
green-lantern's Avatar
Originally Posted by TOM R
If you put a vac gauge on it should read as you raise and lower rpm
This is cause vac advance does nothing at idle so no vac needed at idle
Might want to replace all vacuum lines on engine it is cheap, how are the pcv hoses on valve covers?
I put the hose in my mouth while the engine was running and revved the s#*t out of it, nothing.
I thought there was the most vac on it at idle then when you opened the throttle body it relieved that vac and advanced the timing. Not very knowledgeable on vac advance though.
All hoses are in pretty good shape really.
Old Feb 7, 2014 | 08:53 PM
  #52
TOM R's Avatar
Disco could be reverse to normal cars lol
Old Feb 8, 2014 | 12:51 PM
  #53
True lol
Old Feb 8, 2014 | 08:51 PM
  #54
Charlie_V's Avatar
Originally Posted by green-lantern
I'm sorry; been under the weather. I have a 2000. I know your is different but it is worth checking whether the operative part of the MAF (the part that inserts into the barrel that connects to the intake hose) is the same, because it is so cheap. The 03 and 04 use the same as the 99 to 02, and they are even swappable with some Volkswagens. It is a pretty common part.
Old Feb 8, 2014 | 08:56 PM
  #55
Charlie_V's Avatar
Well, in the interest of honesty and humility I'll leave mast last post up but I checked and yours is vastly different (for a 1995 Disco I). My bad. Sorry for the rabbit trail.
Old Feb 9, 2014 | 05:07 PM
  #56
It's OK lol, I sort of checked into it and just by looking at it I was pretty sure it wasn't going to work.
Hope you get to feeling better
Old Feb 11, 2014 | 07:00 PM
  #57
Well the box under the seat doesn't show any codes :sigh: It seems like I remember it didn't work years ago. Very frustrating to say the least.
Old Feb 11, 2014 | 09:45 PM
  #58
TOM R's Avatar
So when's the dizzy part gonna be in I think this will be the solution
Old Feb 12, 2014 | 05:17 AM
  #59
I talked to Disco Mike last night and he didn't seem to think that's the issue but I'm ordering one today since I know it's bad. Iv'e been sick the last few days so I didn't get around to doing it. I might as well do it right now though.
Old Feb 12, 2014 | 08:41 PM
  #60
oljohnboy's Avatar
Dont know if this helps, I have the 4.0 and I had the same issue with high idle and running like crap. The ECU was bad. It worked but the section that controls the idle had water damage. Check the pins on your ecu and if any show corrosion you might want to get that checked.
