engine swap
i am thinking about doing a engine swap in 2 wks but i need to know if i need any gasket or anything for the new engine.... any good tips on doing this
which chevy clutch fan do i need so i can get it install while i have the motor sitting out and where i can i get the jags engine mount at
Wait until your budget allows you to do the job right the first time if at all possible. You will want to do the hoses and clamps along with fresh coolant at the very least, not to mention an oil change, and probably a basic tune up. How about fixing any leaks on the "new" engine before it goes in? I bet the valve covers could use gaskets, the intake bolts are probably loose, etc. Should have the radiator checked over as well. $150 won't get you very far.
