engine swap
Old Oct 1, 2012 | 08:43 AM
JumPeR04's Avatar
Default engine swap
i am thinking about doing a engine swap in 2 wks but i need to know if i need any gasket or anything for the new engine.... any good tips on doing this
which chevy clutch fan do i need so i can get it install while i have the motor sitting out and where i can i get the jags engine mount at
Old Oct 1, 2012 | 09:20 AM
slanginsanjuan's Avatar
...are you drunk?
Old Oct 1, 2012 | 10:06 AM
JumPeR04's Avatar
nope just dealing wit a newborn lolsorry about that
Old Oct 1, 2012 | 10:34 AM
EricTyrrell's Avatar
You might want new coolant hoses, but I can't think of anything else.
Old Oct 1, 2012 | 02:12 PM
that's cool bro. congrats.
i did the clutch fan..there's a ton of stuff on here about it.
Old Oct 1, 2012 | 02:30 PM
hilltoppersx's Avatar
get the QT mounts from Lucky 8
Old Oct 1, 2012 | 04:38 PM
JumPeR04's Avatar
thanks guys, i am going try to keep it under 150 bucks for the swap since we are on budge...
Old Oct 1, 2012 | 09:11 PM
Danny Lee 97 Disco's Avatar
So what condition is this "new " engine in? Why are you swapping engines? You may be going from bad to worse, and if you only have $150 in the budget, that don't sound very good.
What about the serp belt? Plugs, Plug Wires? Fluids?
Old Oct 2, 2012 | 06:39 AM
JumPeR04's Avatar
the new motor got 110k and i know it is a good motor since i drove it before i pull the motor but on the other hand the one in my rover got little over 200k on it and i am thinking it mite have a blown head gasket and other issue with
Old Oct 2, 2012 | 07:14 AM
Higgs Boson's Avatar
Wait until your budget allows you to do the job right the first time if at all possible. You will want to do the hoses and clamps along with fresh coolant at the very least, not to mention an oil change, and probably a basic tune up. How about fixing any leaks on the "new" engine before it goes in? I bet the valve covers could use gaskets, the intake bolts are probably loose, etc. Should have the radiator checked over as well. $150 won't get you very far.
