Exhaust Manifold and bell housing bolts
Old May 3, 2015 | 07:04 PM
Dogwood's Avatar
8th Gear
Default Exhaust Manifold and bell housing bolts
As I reassemble my " Disco in a box" I find that the PO lost the Exhaust manifold bolts and the Trans bell housing to engine bolts. They both appear to be 3/8" coarse thread, do they need to be grade 5 or will hardware store bolts work. Torque values don't appear to be too high. Any Ideas Thanks Folks!
Old May 3, 2015 | 08:22 PM
ihscouts's Avatar
Go with grade 5 on bell housing and grade 8 on manifold. 33 ft/lbs isn't a whole lot but look at what they're holding so grade 5 is fine on the bell housing. Grade 8 on the manifolds is a personal preference because they're heat treated - handle high heat well. I use them on all my low pressure steam line connections at work not for clamping force but heat handling and reusability which is the key here.
Old May 3, 2015 | 09:53 PM
Dogwood's Avatar
8th Gear
Thanks Ihscout, hadn't thought about the heat treated part.
TripleThreat
Mar 12, 2013 03:23 PM
FrFghtrBRET
Oct 25, 2011 05:40 PM
MarvelVT
Mar 23, 2009 09:53 PM
mburnett
Jun 4, 2008 04:02 PM
telly
Mar 20, 2007 03:02 PM
