Exhaust question
Where the exhaust manifold meets the Y-pipe there are two flat faces with studs and nuts. No split flange. You might use a split flange where the Y pipe meets the exhaust pipes.
Which are you thinking of?
exhaust manifold gasket and stud kit: https://www.roverparts.com/exhaust/kits/ERR551K/
As for the split flange, I have this one in my Disco parts list but put it there so long ago that I cannot confirm it is the correct size...
As for the split flange, I have this one in my Disco parts list but put it there so long ago that I cannot confirm it is the correct size... https://www.amazon.com/dp/B00AZWSGX6...v_ov_lig_dp_it
do you know what size would be best?
