Exhaust question
Old May 10, 2022 | 01:53 PM
Sam95disco's Avatar
Arrow Exhaust question
What size split flange fits on a 95 D1?
where manifold meets the y pipe
Old May 11, 2022 | 01:23 PM
WaltNYC's Avatar
Where the exhaust manifold meets the Y-pipe there are two flat faces with studs and nuts. No split flange. You might use a split flange where the Y pipe meets the exhaust pipes.
Which are you thinking of?
exhaust manifold gasket and stud kit: https://www.roverparts.com/exhaust/kits/ERR551K/
As for the split flange, I have this one in my Disco parts list but put it there so long ago that I cannot confirm it is the correct size...
Amazon Amazon
Old May 11, 2022 | 01:44 PM
Sam95disco's Avatar
As for the split flange, I have this one in my Disco parts list but put it there so long ago that I cannot confirm it is the correct size... https://www.amazon.com/dp/B00AZWSGX6...v_ov_lig_dp_it
my bolt heads broke, I got one holdin up each side. I want to use a split flange to tighten it.
do you know what size would be best?
Old May 16, 2022 | 02:35 PM
WaltNYC's Avatar
I don't. Most would drill it out and either re-tap for new studs, or use nuts and bolts.
jjh221
Jul 21, 2020 09:16 AM
FLA Rover
Sep 18, 2018 09:19 AM
twaszak
Jul 15, 2012 07:21 PM
jimpty
Dec 4, 2011 10:06 AM
Satisfying Pie
Nov 3, 2011 07:10 PM
