Expansion tank swap
Old Jan 15, 2017 | 08:55 AM
stillruns's Avatar
Default Expansion tank swap
I'd like to tackle this today while the weather is cooperating. One I unscrew the tank and unclamp/remove the two hoses to the tank, what next? Drop the new one in and re attach the two hoses? My question is the fluid. Once it drains out when I remove the hoses, and the new dry tank is put in, what amount goes back in the radiator? Recommended antidfreeze? I don't refill the tank correct. Thanks for the help.
Old Jan 15, 2017 | 09:25 AM
number9's Avatar
5. Pour correct solution of water and anti-freeze
into expansion tank until radiator is full.
6. Start engine, run it until normal operating
temperature is attained, topping up as
necessary.
7. Refit radiator filler plug and ’O’ ring, with new ’O’
ring if required. Tighten to 6 Nm.
8. Fit expansion tank filler cap.
9. Allow engine to cool, check coolant level. Finally
top up expansion tank until level reaches seam
of expansion tank.
From your D1 manual.
Old Jan 15, 2017 | 10:09 AM
OverRover's Avatar
" My question is the fluid. Once it drains out when I remove the hoses..."
Make your life easier and make almost ZERO mess with the coolant drain...get a hose clamp set from any Autozone, NAPA, HF like these > 4 Piece Fluid Line Clamp Set or like >> 3 Piece Line Clamp Set
Clamp the hoses, then use a cheap-o siphon pump like this> Siphon Pump - Save on this Fluid Siphon Pump and drain the tank. Remove the hoses and replace the tank.
Refill the new tank/hoses, remove the hose line clamps and check the level in the tank. There will be zero coolant loss from the radiator and no air in the system. To be sure> Run the truck to normal op temp, let it sit until cool and check the level in the tank again. Add coolant as needed (you probably won't need to). Have at it!
Old Jan 15, 2017 | 12:08 PM
stillruns's Avatar
Thank you for the tips. What coolant can i buy at local auto parts store. Any type work as long as its green and 50/50?
Old Jan 15, 2017 | 12:28 PM
OverRover's Avatar
Prestone 50/50 will work. Just a thought, it's cheaper to buy the full concentrated coolant and mix it with distilled water. You are not going to need much coolant to do this repair especially if you use the hose pinch clamps.
Old Jan 15, 2017 | 01:26 PM
stillruns's Avatar
10-4. Headed to Advanced now. Will report afterwards.
Old Jan 15, 2017 | 04:33 PM
stillruns's Avatar
Success! New tank in. Levels appear good. Thanks again. Next up, thermostat. I have it and a new seal in hand. AB has a video on this job and it appears pretty straightforward. Remove two bolts, remove old t stat, insert new one at 12:00. Re attach housing. I am guessing that when you remove the hose that goes to the t stat housing, fluid will come out. Is this a more in depth job regarding the radiator?
Old Jan 15, 2017 | 04:59 PM
OverRover's Avatar
Thermostat is real simple.
Instead of removing the lower rad hose to drain the coolant use the siphon pump you just bought(you did get one right?). This time put the siphon tube into the radiator fill plug and remove approx. 1 gallon of coolant. No mess!
Then remove the upper rad hose @ the thermostat housing. If you are going to replace the upper hose (and you should ) then just remove it from both ends.
NEXT just remove the 2 housing bolts and remove the thermostat. Clean off all the old gasket and put it all back together. Fill and bleed the air....Done.
Old Jan 15, 2017 | 06:00 PM
stillruns's Avatar
10-4. The upper rad hose is fairly new and doesn't appear to have any signs of fatigue. So..
1. Siphon 1 gallon of coolant out
2. Remove end of upper rad hose attached to housing
3. Remove 2 bolts + housing
4. Remove old tstat, clean area, insert new
5. Re attach hose
6. Fill rad with 1 gallon of coolant
7. Fill and bleed air
Old Jan 15, 2017 | 06:11 PM
OverRover's Avatar
That's it. I know once you do this repair with the siphon you won't believe how little to no coolant mess is made.
1 more thought: If you want more access to the therm housing (once the hose is removed from that end) just loosen the upper rad hose clamp @ the radiator and twist the hose up. Really not needed but it can help. I'm out of "good ideas" Good on ya!
aguison
Nov 16, 2012 09:29 AM
ulviking44
Freelander
Jan 6, 2009 01:43 PM
samue23
Feb 25, 2008 07:43 PM
twalter87
Sep 9, 2007 08:47 AM
