Experience w/Disco I w/ 245/75-16 vs 265/75-16?
Old Sep 26, 2014 | 01:47 AM
  #31
EricTyrrell's Avatar
Originally Posted by fishEH
It's a big heavy brick on wheels with an underpowered engine.
All the more reason not to make it worse than needed.
Old Sep 26, 2014 | 05:36 AM
  #32
MM3846's Avatar
ya. not to mention larger tires + stock gears = unhappy transmission. whether its an auto or manual, it isn't good for it. once you drive a rig thats geared up, you can't ever go back.
Old Sep 26, 2014 | 08:19 AM
  #33
fishEH's Avatar
IDK, I think people make more out of regearing than need be.
Personally I don't know anyone who has regeared to run 235/85/16, and certainly not for 245/75/16. None of their transmissions have blown up. I know a LOT of guys running 33" tires and none of their transmissions have blown up either. In these trucks the trans is about the last thing to go. The engine is far more prone to failing.
The cost involved really just isn't worth the results. You're talking about a good amount of work and a lot of expense for very marginal "performance" gains. If you're going to open up your diffs and pay the expense to regear you might as well do it for more gains than a 235/85 or a 245/75. Gears pretty much cost the same whether its a 3.54 or a 4.71. So if you INSIST on regearing you might as well get the most out of your money. Run a 33" tire and regear to 4.11(4.12) and throw a locker in there.
I urge you to run the gear calculator here with different tire gear combinations and see what effects each has. http://www.ashcroft-transmissions.co...atio_calc.html
Here's some commonly available gears. Coil Sprung - Diff Gearing
Of course its your truck and you can do whatever you want. You just have to take people's advice with a grain of salt and consider their opinions vs their actual experience.
Old Sep 26, 2014 | 09:03 AM
  #34
Buddy Lee's Avatar
I would agree regearing for anything less than a 33" tire is not needed. At 33" you'll start to notice the difference a lot more. I'm currently running 315/75's (35ish tire) on stock gears and it is definitely a dog. It's also a pain because that's roughly 16% above stock and since the Torque converter does not lock up until ~50mph I have to be doing around 60 before it locks up. Which does not happen often.
This winter I'll probably bite the bullet and get some 4.7x gears put in because the lack of power is really starting to bug me.
Old Sep 26, 2014 | 09:23 AM
  #35
fishEH's Avatar
Dang, that's a lot for stock gears!
I used to run 265/75/16 on stock gears. Now I run 315/75/16 on 4.12 gears.
the 315/75 on 4.12 is closer to stock gears/stock tires than the 265/75 on 3.54 gears was, so that's good enough for me. Lock up is still around 50-52mph.
Old Sep 26, 2014 | 10:00 AM
  #36
Buddy Lee's Avatar
Yeah I know it's pretty bad. But I've been slowly drying to build the truck back up since I got it back last year. It used to have 4.11 gears but those where pulled by one of the owners between when I sold it and when I bought it back. I got a smoking deal on a Detroit and TT last year but they were on stock gears so I just threw them in for the time being. But I think once I save up my lunch money this fall I'll spring for some new diffs.
I did the math on all the different gears. The 4.11's are close to stock (+3%) but this is my trail truck and hardly sees road use so I'm going lower than stock. The 4.75's should put me at -12%. Which I think will be just about right for what I do.
Old Sep 26, 2014 | 10:15 AM
  #37
fishEH's Avatar
Right on. I have to drive pretty much anywhere I wheel. 3-4 hours each way is about average so I didn't want too tall of gears. Plus I got my front and rear 4.12 R&P's for about $250 shipped so that influenced my decision.
Your truck looks great BTW.
Old Sep 26, 2014 | 01:36 PM
  #38
Buddy Lee's Avatar
Thanks,
I used to do the same thing. But I'm just getting too old to worry about if the truck is going to make it home on Sunday. Plus I get the same or better mileage towing as I do driving. I averaged 12.1 mpg doing 70-75 on my 800 mile round trip to SAE.
Old Jan 9, 2025 | 12:25 PM
  #39
Isueyu's Avatar
265/75/16 on a 2 inch terra firma lift for reference...
And without lift (mine definitely self clearanced before the lift was installed.)
taylor15
Sep 17, 2014 04:50 PM
disco202
Feb 1, 2012 10:31 AM
oysterhead
Dec 30, 2009 05:32 PM
swellseeker
Feb 5, 2007 11:59 AM
