Factory Front Amp Location
Old May 22, 2016 | 04:41 AM
ImNotTheStig's Avatar
Default Factory Front Amp Location
Attempted to install a new head unit tonight into the Disco, and ran into some problems. I believe I will have to bypass the factory amp to get sound though the speakers, which wouldn't be an issue, if I could find the darn thing! From what I have found online it will be a small black box behind the glovebox/passenger footwell with two connectors and an exterior fuse, but I can't see anything that fully fits the description. Can someone who has done this before help me out? I think it may be this one, but before I cut wires and disconnect things I want to be sure...
Picture is taken of behind the glovebox
Thanks for any input.
Old May 22, 2016 | 09:37 AM
aemnky606's Avatar
Take a look at this thread you will be able to use your existing amp as long as its not bad. https://landroverforums.com/forum/di...install-76839/
but the amp is behind the trim piece on the right side of the glove box.
Old May 22, 2016 | 11:52 PM
So it turns out the I was literally sitting on the answer the whole time... my amp was under the passenger seat. Maybe models without power seats had them located here? Anyways, that thread is perfect, but I am unable to open the attachment for the wiring diagram because I don't have permission... so the search continues. Thanks for the help though Aemnky606!
Old May 23, 2016 | 11:09 AM
WaltNYC's Avatar
The arrow in your picture is pointing to the power window ECU.
Old May 23, 2016 | 08:21 PM
Good to know, thanks.
Old May 27, 2016 | 05:33 AM
FLA Rover's Avatar
On LSE driver side under seat is amp, under passenger seat is cd changer.
Old May 30, 2016 | 01:05 AM
Ah ok, my one was the opposite, CD changer under driver. Regardless, she's all wired up now and sounding much better than before.
Alex_M
Sep 29, 2015 01:35 PM
bmwtinut
Nov 3, 2014 04:47 PM
tjhappel
Feb 20, 2011 07:54 PM
wolfgang528
Defender
Dec 28, 2010 04:25 PM
Roveroh
Aug 7, 2008 09:42 AM
