Fan Clutch Thread
Old Sep 14, 2010 | 12:02 PM
bmxermike's Avatar
Default Fan Clutch Thread
I purchased a fan clutch from autozone and the thread is opposite (turn left to tighten). I read in the Rave manuel that you turn anti-clockwise to loosen the fan clutch. So before I tear into it I just wanted to double check if I have the correct part.
Discovery 1
Old Sep 14, 2010 | 12:12 PM
antichrist's Avatar
D1 serpentine belt fan clutch thread is right-handed.
Old Sep 14, 2010 | 12:18 PM
bmxermike's Avatar
so when looking at it from the front of the truck turn the thread clockwise to loosen?
Old Sep 14, 2010 | 12:38 PM
kenk's Avatar
My fan clutch came off counter-clockwise, goes tight clockwise, as viewed from the front
Old Sep 14, 2010 | 01:04 PM
bmxermike's Avatar
well I'll just have to try both ways, I am replacing the water pump also so it shouldn't be too difficult with the whole unit removed. Hopefully mine goes loose clockwise, if not I have the wrong clutch.
Old Sep 14, 2010 | 01:35 PM
kenk's Avatar
Think you do, if it is truely left hand threaded
Old Sep 14, 2010 | 01:56 PM
antichrist's Avatar
Sorry, brain fart. I double checked and it's right hand thread. I fixed my original post.
Here are the Imperial fan specs, 157 is regular duty (B), 158 is severe duty (D)
Size:  6.2 KB Name:  SD-fan.jpg
Old Sep 14, 2010 | 02:06 PM
bmxermike's Avatar
I definitely have the wrong part then. Is there any disadvantage to drilling and bolting the old one to lock it up until I can get the correct one?
This is the part I have: http://www.autozone.com/autozone/par...1_194143_6245_
Old Sep 14, 2010 | 02:52 PM
okdiscoguy's Avatar
Did you stick your finger in it and check the threads? That is the right part. Reverse rotation does not mean the threads are backward.
Old Sep 14, 2010 | 03:03 PM
bmxermike's Avatar
Thats good news. I did look at the threads and thought they were backwards but I'm sure I just got confused. I'm going to install it tomorrow, I'll post how it goes. Thank you for all the helpful replies.
