Final drive
Old Sep 2, 2015 | 01:32 PM
discoguy96's Avatar
Default Final drive
I posted a couple days ago about my differential going out. I picked up a complete rear axle assembly off a 96 with only 88k miles. The flange that bolts to the propshaft is 3 bolt but mine is 4 bolt. Can i remove the flange without removing the pinion gear or is it pressed onto the pinion shaft?
Old Sep 2, 2015 | 02:28 PM
OverRover's Avatar
" Can i remove the flange without removing the pinion gear or is it pressed onto the pinion shaft? "
Yes, and it looks like this>>>
Clearday714
Nov 11, 2011 05:42 PM
Disco2Fever
Apr 16, 2010 03:43 PM
alanroberts50
Sep 27, 2009 01:53 AM
RealRitzcracker
May 31, 2009 03:24 PM
andrewmcoffin
May 30, 2008 08:09 PM
