First CEL code in over a year...
I replaced the front 2 a year ago when I had my last bout with a CEL, so maybe I will replace the rear 2 now. Do you happen to know if the multi-function relay under the hood controls the heaters in the o2's? Cause I think mine is bad, and that would explain that.
I just replaced one of mine at 84K (i know i should have done all of them but i'm poor) and got it off amazon for a 99 DI for $60 per. Fit perfect.
http://www.amazon.com/s/ref=nb_sb_no...ords=ngk+25044
perfect fit means nothing. Working perfectly means everything. Buy them from AB reason being is they are different from previous years. They look the same but are built for AEL.
97 was the cutoff year.
I replaced the 2 in front last year due to a code for bank A, did the back 2 recently.....seems to be running smoother and the mileage is a little better now that the ecu has had time to compute. I went with the ones from AB .
just a note .....the thread size of the sensor is 12mm-1.25 you may want to have a tap handy as one of my front ones messed up the threads getting it out and the new one wouldn't go back in with out cleaning up the threads in the pipe first.
SolbergFanBoi
Mar 5, 2012 07:05 PM
