First LANDROVER DISO 1
Not really. I just use the cheap, worthless software that came with it. Might be better if I used better software. And I use it with my laptop because I don't have any apples.
Get the UltraGauge. Works perfectly. Also, your valve cover bolts will need tightened at ever oil change. Just the nature of the beast.
Valve covers loose solution = Mark 1 palm attached to socket wrench with 8mm 12 point socket, will need slim shank one if 3/8 drve, bought mine at Lowe's. Some snug them each oil change.
I don't have an android either.
Premium
Fuel
8.13:1, non catalyst .................................................. ........ 91 RON minimum unleaded
9.35:1, non catalyst .................................................. ........ 95 RON minimum unleaded
9.35:1, catalyst .................................................. ............... 95 RON minimum unleaded
USA-Premium unleaded (PUG) ....................................... CLC or AKI 90 octane minimum
95 RON minimum9.35:1, non catalyst .................................................. ........ 95 RON minimum unleaded
