fixin some alpine rust
on
popping them out is easy, getting them back in is still up in the air. as for the rust, it wasn't as bad as i though it would be, I just ground it off with a flap wheel and sprayed it with rust converter and painted it. it is done, but i ran out of time cause the paint won't be dry enough to put the glass in tonight
on
I'm glad there weren't any holes yet but I would think if it were right on the edge where the rubber has to slide over you would have to weld them up, any where else if they were small I would try to bondo. the steel is thin and I wouldn't want to burn through it trying to weld an 1/8 inch hole or two.
