fixin some alpine rust
Old Nov 3, 2010 | 03:38 PM
tweakrover's Avatar
Default fixin some alpine rust
I'm thinking about painting the whole roof with this flat tan paint
Old Nov 3, 2010 | 04:45 PM
What are you going to do about the rust?
Old Nov 3, 2010 | 04:52 PM
kenk's Avatar
How hard are them windows to pop out? Do you have to remove any interior bits?
Old Nov 3, 2010 | 04:57 PM
tweakrover's Avatar
popping them out is easy, getting them back in is still up in the air. as for the rust, it wasn't as bad as i though it would be, I just ground it off with a flap wheel and sprayed it with rust converter and painted it. it is done, but i ran out of time cause the paint won't be dry enough to put the glass in tonight
Old Nov 3, 2010 | 04:58 PM
tweakrover's Avatar
oh yea you have to pull the inside panel around the alpine
Old Nov 3, 2010 | 08:20 PM
Danny Lee 97 Disco's Avatar
I have little rust thru holes I need to deal with, anybody been there done that?
Old Nov 4, 2010 | 08:51 AM
tweakrover's Avatar
I'm glad there weren't any holes yet but I would think if it were right on the edge where the rubber has to slide over you would have to weld them up, any where else if they were small I would try to bondo. the steel is thin and I wouldn't want to burn through it trying to weld an 1/8 inch hole or two.
Old Nov 4, 2010 | 04:51 PM
tornado_735's Avatar
I just patched the hole I created (by poking with my finger no less) with black silicone. Problem solved!
Old Nov 4, 2010 | 05:07 PM
kferg's Avatar
Been there, done that. Its not a bad job to get them back in, actually pretty easy on the '95. I used POR15 putty/filler to patch the holes in mine and re-build the lip where the moulding seals.
Old Nov 4, 2010 | 09:06 PM
tweakrover's Avatar
to put them back in did you pull the rubber wedge strip out, and put the rubber in then the glass in the rubber then the strip back in, or the glass into the rubber then the whole thing back in the hole?
