flooded the engine now what? lol
Old Feb 2, 2011 | 05:41 PM
cationmoted's Avatar
Talking flooded the engine now what? lol
while i was plugging in the o2 sensor i was hitting the throttle cable
i started the rover then the revs jumped to 3-4000 revs shut it off after 10 sec
im guessing its flooded
what now?
should i wait?
thanks
Old Feb 2, 2011 | 08:20 PM
You cant flood a fuel injected engine by giving it throttle with the engine not running.
The fuel injectors only inject fuel when the cam sensor tells them to, no input from the cam sensor no fuel.
You have something else going on.
Old Feb 2, 2011 | 08:28 PM
hilltoppersx's Avatar
i would check the throttle cable is not stuck, maybe you hit it somehow and it got stuck or check the CC cable is not stuck on something leaving the throttle partially open.
Old Feb 2, 2011 | 08:30 PM
thank you for your reply
do you think the new oxygen sensors have something to do with it?
the car hadnt been driven in 2 weeks
how ever i started it 4 days ago to move it (it was fine then how ever after letting off the gas the revs would climb then go down rapidly
when i start in now the revs raise to 1500 then immediately go to 3000 and increase i shut it off after it got to high
any suggestions on where to start diagnosing?
once again thank you
Old Feb 2, 2011 | 08:38 PM
will do, could you please clarify on what a cc cable is? im a noob still thx
Old Feb 2, 2011 | 09:39 PM
Spencerfitch's Avatar
aww shoot.. This dont sound good..
Check the throttle linkage, there is a little black wheel you can tighten and if you do it will open the throttle.
The you should see it and then a little black wrinkley cover over the cable and then see where the cable attaches to the throttle. It should have a little play in it. Put your finger under it and pull a little make sure its somewhat loose. Better to be loose than tight.
Old Feb 5, 2011 | 08:49 PM
ok fixed it, a guy helped me do it he floored the engine redlining it, while i was s***t*ng my pants and wallah the revs went back to idling speed
thanks for the suggestions and help
Old Feb 6, 2011 | 07:40 AM
cruise control
Old Feb 6, 2011 | 09:13 AM
So what was the problem?
Old Feb 6, 2011 | 09:38 PM
im not sure, the guy who helped me fix it just said it wasnt driven enough.
the rover has not acted up since so im hoping everything is some what back to normal..
saidrover
Dec 29, 2012 12:12 AM
chrisr
Nov 27, 2012 06:11 AM
samue23
Aug 26, 2012 02:36 PM
robertnsmith
Apr 6, 2010 05:59 PM
khuds308
Mar 27, 2008 09:08 PM
