Fluid change
Have at it!
And I'm not suggesting you spend $159.95 on the fluid change kit ( DTCM600A ), but you might find the video useful.
> Differential And Transfer Case Service On Discovery I
Those videos are usually pretty good, but this one can get you in trouble.
ALWAYS REMOVE THE FILL PLUG FIRST! Then pull the drain plug.
If you run into some problem with the fill plug you wouldn't be able to run the truck without oil in the differential if you pull the drain first.
collin Barrows
Aug 28, 2011 07:13 AM
treant985
Dec 27, 2010 02:51 PM
LRScott
Mar 4, 2009 08:39 AM
