Fluid change
Old Mar 23, 2018 | 08:52 AM
ShaggySE7's Avatar
Default Fluid change
I'm about to drain and fill both diffs, swivels, and T case. How much gear oil will I need?
Old Mar 23, 2018 | 06:39 PM
OverRover's Avatar
Have at it!
And I'm not suggesting you spend $159.95 on the fluid change kit ( DTCM600A ), but you might find the video useful.
> Differential And Transfer Case Service On Discovery I
Old Mar 26, 2018 | 09:11 AM
WaltNYC's Avatar
Those videos are usually pretty good, but this one can get you in trouble.
ALWAYS REMOVE THE FILL PLUG FIRST! Then pull the drain plug.
If you run into some problem with the fill plug you wouldn't be able to run the truck without oil in the differential if you pull the drain first.
Athana
Jun 8, 2019 10:23 AM
1998DiscoverySE
Jul 20, 2012 08:02 PM
collin Barrows
Aug 28, 2011 07:13 AM
treant985
Dec 27, 2010 02:51 PM
LRScott
Mar 4, 2009 08:39 AM
