forward sunroof
Old Apr 10, 2013 | 09:16 PM
bassinbob's Avatar
5th Gear
Default forward sunroof
forward sunroof will not operate
where is the logical place to start
real one works great
any help
bob
Old Apr 10, 2013 | 09:52 PM
You start by sealing it shut with marine grade silicone and then unplugging the switch.
Then if you were wise you'd do the same with the rear.
Old Apr 11, 2013 | 06:33 AM
TOM R's Avatar
I am sure the rave manual has a diagnosis proceedure, does it at least make noise?
could be bad motor, bad switch, bad ecu for sunroofs, etc.
rave manual here
http://apicdn.viglink.com/api/click?...ction-32402%2F
Old Apr 11, 2013 | 06:46 AM
Paul Grant's Avatar
If you hear the motor, it's most likely the rails. If you don't hear anything at all either you're not getting power to the sunroof motor or the motor has gone bad. Once you've done your diagnostics and know what you need to get the sunroof working let me know. I have all the parts in stock that you might need. They are used, with a warranty and typically come from later model DII's so they are newer than those used on your DI.
Old Apr 14, 2013 | 05:36 PM
droptine77's Avatar
Thats the smartest thing I've heard all day. Mine leaks like a sum beach and you can't hear crap when you open them anyway. Think thats what I'm gonna go and forget about it.
Old Apr 14, 2013 | 06:27 PM
Sam95disco's Avatar
That's what I did. I used roofing silicone(black). I fixed all my outside window gaskets with it.
Old Apr 14, 2013 | 06:33 PM
I have not opened mine since I test drove my truck back in '07, they dont leak, but I do not open them, messes up my hair.
Old Apr 14, 2013 | 07:22 PM
TOM R's Avatar
they are definitly super loud when open if you have the roof cross rails in but nice to let out the summer heat when you first get in
op the ecu for them is behind the buttons on the ceiling
transpartstech_rover
Mar 2, 2010 02:13 PM
Macattac
Sep 29, 2008 02:07 PM
skunkridge
Dec 9, 2007 10:18 AM
thordehr
Oct 30, 2007 08:14 PM
elguappo999
Nov 10, 2006 09:08 PM
