Found my coolant leak and then some
Old Mar 1, 2019 | 04:27 PM
OverRover's Avatar
Originally Posted by whiskeynipple0088
nope no petcock
- brilliant Land Rover
- get yourself a cheap hand pump from Harbor Freight
+1.... these cheap $5 syphon pumps from HF, Napa, H Depot, wherever gets the radiator empty fast (under 5 minutes total).
Old Mar 1, 2019 | 04:59 PM
dialtonehero57's Avatar
Talking
should be easy. Does the block drain into the lower hose and therefore drain the block also? So one can change the water pump?
Old Mar 2, 2019 | 06:27 AM
OverRover's Avatar
Draining the radiator with the syphon pump does not drain the block, but it removes more than enough (like 95%) to change the water pump.
But once you remove the lower long bolt (drivers side) that goes through the water pump/ front cover and into the water jacket
the rest of the coolant (to replace the pump) will be removed.
Just put a small bucket/oil change pan under the crank pulley to catch the rest of the coolant.
You can see this in the video (I know it's a DII but same rules apply) just start at 5:10
> https://www.roverparts.com/resources...t-discovery-2/
Old Mar 2, 2019 | 10:55 AM
Talking
@Over Rover that’s very good info. I watched the video and the water pump looks easy. I’ve done them numerous times on American vehicles. I need the fan clutch tool. Everything else is standard wrenching. Is that parts house good for prices?
Old Mar 2, 2019 | 01:40 PM
ihscouts's Avatar
Make one, it's what I did. What kind of cheap American buys a silly fan clutch tool?
Old Mar 2, 2019 | 01:48 PM
Talking
you crack me up 😂 I’m on it! What’s that dimension of that nut 🥜?
Old Mar 2, 2019 | 02:01 PM
ihscouts's Avatar
It's bigger than it should be - 1 1/2". If you're going to make a wrench (which it appears you are) all you need is to get the width close enough to wiggle wiggle on. Try 1/4" flat stock by 2 1/2 wide, that'll show it who's boss.
Old Mar 2, 2019 | 02:20 PM
OverRover's Avatar
AB is fine for parts, but on the higher side for prices (they do price match).
Bonus for you they have a West Coast warehouse since they bought out British Pacific.
Another great place close to you is Trevor at RovahFarm > https://rovahfarm.com/discoopeningpa...er%20parts.htm
And for many reasons you can't go wrong with Lucky8 > https://www.lucky8llc.com/
The nut on the Fan Clutch (ERR3443) is 36 MM, and you can always rent the wrench and a Fan Clutch Holding Tool from Autozone.
Old Mar 2, 2019 | 03:58 PM
Talking
those dimensions will leave about 1/2” of material on each side of the nut. How long is your handle?
Old Mar 2, 2019 | 05:04 PM
ihscouts's Avatar
Long enough to reach above the fan shroud to smack with a mallet. Probably around 18” to 20” long. 2.5” wide leaves .5” either side of the 1.5” nut to grab it with. My widget is plased out of .5” stainless stock and I TIG welded a handle to it, I get bored sometimes.... I’ve never taken to crocheting.
