Found my coolant leak and then some
Old Mar 4, 2019 | 07:16 PM
  #31
dialtonehero57's Avatar
Originally Posted by ihscouts
How many miles on the odometer? If it's over 120k then you might be in for a bigger surprise than just a simple leak. Like Subi's the all aluminum Land Rover slug box likes to crap head gaskets like their free. I'd bet a buck that is why the heater core is bypassed and all the other hillbilly fixes. The fan clutch is the number one part that needs replacement every 30k or so, even if it isn't overheating it's good insurance against it and don't skimp on it. It's the most overlooked part of any cooling system and it begins the cascade of all the other cooling failures when overheating begins with these motors. You check the head gaskets by doing a simple compression test with bleed down. If a cylinder is bleeding down fast it's more than likely the head gasket. The other test is run the engine cold for 40 seconds and shut it off. If you get pressure when removing the radiator plug on top then it's a head gasket. Real simple test. If you want to go another route you can run the motor until the thermostat opens with the fill plug off, if you get bubbles making a run for it...... it's a head gasket failure.
this is the “fill plug” you are referring to correct?
Old Mar 4, 2019 | 07:21 PM
  #32
Default F word
I must assume this mean I have head gasket issues
Old Mar 4, 2019 | 07:31 PM
  #33
Default Head gasket ?
This is running at about 2 mins
Old Mar 4, 2019 | 07:38 PM
  #34
stillruns's Avatar
What am I missing? Why isn’t the cap/plug on there?
Old Mar 4, 2019 | 07:44 PM
  #35
i ran it with the cap off looking for bubbles. My video would not upload so I snapped a screenshot
Old Mar 4, 2019 | 08:13 PM
  #36
ihscouts's Avatar
​​​​​​Correct.
Old Mar 4, 2019 | 08:21 PM
  #37
​​​​​​Correct.
who the heck would design a plastic radiator plug? Oh yeah this is a british truck! Does someone make an after market metal one?
Old Mar 4, 2019 | 08:28 PM
  #38
ihscouts's Avatar
Hit my sig for brass plugs,
Old Mar 4, 2019 | 09:11 PM
  #39
Not seeing your sig in full mode
Old Mar 5, 2019 | 01:50 AM
  #40
ihscouts's Avatar
It doesn't show when I reply from my phone apparently. How about now?
