Found this in oil pan. What is it?
Motor was rebuilt by a machine shop. Been ran for about 15 minutes total. Has a tap on passenger side. Drained oil and pulled the pan for inspection and found this in the pan. Any clue what it is?
![Found this in oil pan. What is it?-forumrunner_20160201_145421.png](https://landroverforums.com/forum/attachments/discovery-i-39/28897d1462298688t-found-oil-pan-what-forumrunner_20160201_145421.png)
Also, I have silver dust in the oil and a max oil pressure of 30 psi. Bearings?
On a full rebuild there should be metal in the break in oil that's why you use the hi zinc break in oil, that could also be some old leftover crud from them cleaning the block
When I first ran mine it made some noises oil light was off but made noises I did not like, they went away after I ran it a bit and drove it around so idk, and yes its scary having noises on a brand new engine
yes, the spacer is from one of the valve cover
finding that kind of particulars is normal on a rebuild that is why you change your oil after 500miles.
why did you shut it down after 15 minutes, it takes longer than that to bed the cam and lifters
Refill with rotella and dump in some break in additive for good measure, iirc I did cut my filter open when I drained the breaking oil and there was a little bit of metal , its normal IMO that's why its called break in
If you are real concerned about a noise video and post it
