Found some rust...
Old Aug 9, 2015 | 12:37 PM
june82000's Avatar
Default Found some rust...
Just picked this up and was doing the cursory clean up, vacuuming etc and discovered some rust in the rear bed area above the gas tank. Not a huge deal, I've certainly seen worse. Has anyone done this fix before? It almost looks as if the rear bed at least partially bolts in from underneath, but I can't imagine it would be that easy.
Old Aug 10, 2015 | 06:43 AM
june82000's Avatar
Bump, pic added...
Old Aug 10, 2015 | 07:59 AM
drowssap's Avatar
common D1 problem, if you run a search you should come up with a couple good post on repairs
bosshogt
Dec 23, 2011 10:24 AM
tweakrover
Nov 6, 2010 10:43 AM
RROJ
Jun 1, 2010 12:57 AM
salve7
Nov 25, 2009 09:58 PM
caitlinfaye1
Defender
May 29, 2009 02:54 PM
