Front Blower Motor won't run
Old Dec 12, 2010 | 06:19 PM
thecardoc's Avatar
Default Front Blower Motor won't run
The slide switch works . The resistor works . I found a relay up by the blower housing Denso # 068700-3300 it has a condom over it . If I manually close the contacts on this relay the Heater Blower runs as is intended. All speeds work fine when contacts closed .
So I assume this is the blower fan relay. I have no wiring diagrams so does anyone know where this relay gets it power from.
Old Dec 13, 2010 | 03:14 AM
Long Haul's Avatar
Sounds like you have a bad relay if you close the contacts and everything works fine. What year is your truck that might be a little more helpfull narrowing down your diagram. There are wiring diagrams in the Rave manual that might help you. Its a free download I just forget the website off the top of my head, if you do a search its out there.
Old Dec 13, 2010 | 09:18 AM
thecardoc's Avatar
It's a 96 Disco I don't think it is the relay because it has no trigger signal coming in to it to energize the coil. I have RAVE but does not help.
Old Dec 13, 2010 | 08:56 PM
Danny Lee 97 Disco's Avatar
RAVE has the electrical if you look in the correct section.
angrylobster
Jun 28, 2015 04:43 PM
m3dragon
Feb 24, 2015 10:08 AM
wisconsinoverlander
Apr 26, 2012 10:24 AM
phidelt583
Dec 29, 2010 11:04 PM
