Blower Motor won't come on
Old Nov 29, 2010 | 09:39 AM
phidelt583's Avatar
Angry Blower Motor won't come on
OK so I have a 99 Disco 2 and my blower motor won't come on at all. My a/c is working fine, evaporator is cold, the blower is the only thing not working. So far this is what I have done:
1. Tested both relays, they both work and have appropriate resistances
2. Purchased a used dash unit ( ac control), no change at all, so I doubt that I purchased a used one with the exact same problem I have.
3. Purchased a New blower motor, no change in problem
4. Tested electrical at blower motor, Good continuity on ground side, power side is like 3-5 volts. There is zero volts when the blower is turned off and 3-5 volts no mater what speed i set the blower to. And it also doesn' t change based on fan speed chosen. I say 3-5 because if varies the whole time I'm testing it. This is where I got real confused, why is there any voltage? how much voltage should be here? 12?
5. All fuses are good as well
I know that alot of people say that the transistor can cause the blower to function only on high, could this part also cause the blower to not function at all? I really don't want to spend money replacing parts, nor do I want to take it to the land rover dealer. so PLEASE someone help!!!
Old Nov 29, 2010 | 03:58 PM
LR03NJ's Avatar
Try hitting the fusebox in the engine compartment with a screwdriver handle. That happened to me. Connectors inside are loose. Happens all the time.
Old Nov 29, 2010 | 04:25 PM
losinov's Avatar
What about the resistor pack that is up under the passenger side dash. I have to also get that fixed in mine. It is only turning on when the fan is on 4. How did you get the dash unit out? I am having trouble figuring out how the dash comes apart in my 94
Old Nov 29, 2010 | 04:34 PM
Alex J's Avatar
Could need a new blower motor resistor.
Old Nov 29, 2010 | 10:38 PM
mherson's Avatar
I had the same issue a few weeks ago on my 01 Disco II with 150K miles. I purchased a used passenger fuse panel from a guy on craigslist for 40 bucks and my blowers started working again. Very easy to swap out the wires and install a new one.
Did your rear a/c blowers work? Before I changed the panel none of the blowers were working.
Message me if you want the name of the guy who I bought this from as he said he had more.
-Matt
Old Dec 29, 2010 | 11:04 PM
antare's Avatar
-Matt
can you send me the name of your craiglist contact?
Cosmic88
Mar 9, 2011 06:53 AM
thecardoc
Dec 13, 2010 08:56 PM
lifewithoutanet
Mar 7, 2009 03:53 PM
97green
Jul 2, 2008 02:58 PM
95Discovery
Jan 7, 2006 08:46 PM
