front brake problem
Old Mar 27, 2012 | 04:21 PM
landroverExtreme29's Avatar
4th Gear
Default front brake problem
my brakes went out and had to replace the master cylinder. I replaced the cylinder and a day later my front brakes locked up. I released the pressure from the abs unit so i could drive. the weird thing is my front brakes would lock up even when im not pressing the brake. I could be driving and they'll lock up. any thoughts what it could be?
Old Mar 27, 2012 | 04:27 PM
wheelgarage's Avatar
Locking most commonly is caused by air in the system...
Was the entire system bleed?
Old Mar 27, 2012 | 04:32 PM
4th Gear
i had the system bled but still the same problem, but why is it just the front brakes.
Old Mar 27, 2012 | 04:38 PM
First...read this post:
https://landroverforums.com/forum/di...p-42392/page2/
Then, if that has not sorted it, it could be the brake proportioning valve located under the master cylinder.
Old Mar 27, 2012 | 04:48 PM
4th Gear
do u know where i could get one. they"re expensive at the dealer.
Old Mar 27, 2012 | 05:04 PM
4th Gear
i looked at the thread but i replaced the master cylinder twice already. its not just one caliper its both. Could it be the brake booster, or does anyone know where i could find a proportioning valve besides the dealer?
Old Mar 27, 2012 | 06:28 PM
Chris-bob's Avatar
The only thing that applies pressure is the master cylinder and the abs. If the abs is not pumping, then it is the master cylinder. The brake booster only boosts the force you apply to the master cylinder. If the master cylinder was installed with the linkage too long, then the master cylinder might be slightly applied and not letting the brakes release.
Old Mar 27, 2012 | 09:32 PM
Your master cylinder needs adjusting.
It is set up wrong.
SolAeon
Jul 10, 2012 09:05 AM
ctystrickland
Feb 15, 2011 07:54 PM
tibyABv6
Jan 7, 2011 06:02 AM
Florida04RR
Mar 10, 2010 06:09 AM
bigbris1
Jul 3, 2007 08:02 PM
