Front doors won't open from the inside
Both of my front doors won't open from the inside and my driver seat is sagging... The dealer says the doors are an easy fix, $142 per hour, 90 min job each side, $22 part, there has got to be a easier and cheaper way. The driver seat seems easy enough, whatever was supporting it gave way. And, she is a 1994 Land Rover Discovery. Any push in the right direction would be greatly appreciated. Thanks in advance.
Hello,
I have something similar on my Disco - I haven't specifically tried to figure out the problem - but - for my situation - the issue seems to be related to the locks, I have to push the locks down and then pull them up (manually), and then the doors will open. Is this a similar situation for you? You don't mention many details regarding the door issue you're experiencing.
As for the seats - Here's "DIY Seats" link - duct tape at it's best...
In Peace and Agape,
Trav...
In Peace and Agape,
Trav...
When you pop the door panels make SURE you are isolating the retaining clips. They're set into your 18 yer old foam backed door panels. So if you're not pulling on the clip itself, that little S.o.b. is gonna rip right out of your door panel and leave you with one that can't be fixed back to the door.
So yeah, pop the dor panel, takes like, four minutes, then just lock and unlock the door until you figure out what is or isn't working, then replace it. And when yo do it, tell the dealership to go jam themselves.
142$/hr yeesh. you can get lawyers for cheaper than that.
This is why your door will not open from the inside, these springs get weak with age.
The springs ARE door specific!!!
The left doors use the same spring, the right doors use a different spring but they both use the same one.
http://cgi.ebay.com/Land-Rover-Disco...item20bb10560b
Ok, thanks guys, fixed my seat issue with some strapping I found at Home Depot for $7, better than new and to clarify on the door issues, I can open from the outside for both front doors, the front passenger aftre like 3 pulls, the driver well, I have to roll the window down for that... I will look into the springs and hopefully its something I can do myself.
Land Rover Discovery Door Lock Repair Spring 5 door set | eBay
My only other recommendations: buy the complete set (save money & time for when the next spring goes) and have some graphite lubricant or door lock spray to lubricate everything while you are in there. Good luck, I took pictures before/during disassembly to make sure I could put it back together properly, but it was fairly logical and straight forward.
marlymarl
07-28-2005 12:23 AM
