Front Engine Cover Leak Write Up
Old Apr 26, 2018 | 05:48 PM
jackyak's Avatar
3rd Gear
Default Front Engine Cover Leak Write Up
Hi Everyone,
I have posted a write-up of my recent adventure in replacing the front engine cover gasket and other bits hidden behind it. Feel free to review and use, it was a success! I hope it is helpful!
1998 Discovery I LSE, GEMS V8
https://www.dropbox.com/s/b41vebtxto...COVER.pdf?dl=0
Cheers,
Jackyak
oil pump, timing chain, oil pan gasket, front engine cover,rotella
Old Apr 26, 2018 | 08:13 PM
nickhand's Avatar
Originally Posted by jackyak
Hi Everyone,
Cheers,
Jackyak
Very useful write-up thanks
Old Apr 27, 2018 | 07:57 AM
WaltNYC's Avatar
Nice first post. Thank you and welcome to the forum!
Old Apr 30, 2018 | 10:05 AM
vanbadri's Avatar
Noooo, the orange RTV!!! Some idiot put the front cover back on my truck's engine using only orange RTV, which eventually led to a blocked coolant passage and a blown head gasket. They likely did that because the front cover wouldn't seal after the damage they did levering it off the block with what was probably a screwdriver. If your mating surfaces are dinged up, you can JB weld and then sand them. Did that on mine and the gasket alone seals fine.
Old Apr 30, 2018 | 11:24 AM
jackyak's Avatar
3rd Gear
RIGHT?!?!
When I see orange RTV, I immediately consider it a problem. I have walked away from used car sales when I see it in the engine bay. I like the JB weld idea a lot or any that reduces the use of RTV in any way for that matter. The new paper gasket that I bought had a thin line of black rigid material on one side down the centerline of the gasket, but it was not continuous and I did not want to risk ANY leaking.
Cheers.
Alex_M
Nov 7, 2025 11:55 PM
7smoothoperator7
Oct 19, 2014 07:09 AM
tmtegt
Mar 20, 2013 07:31 AM
Chrisinhouston
Feb 16, 2008 09:33 PM
