Front Parking Lights Not Working
I just bought a 98 Discovery 1 LSE and I'm tracing down all of the issues with it. The problem that i'm working on now is that the front parking lights and side markers don't turn on. The signal works, and when i lock the doors the markers and parking lights flash, so i'm at a loss.
I tried reading through the RAVE wiring diagrams, but i can't comprehend that.
Any ideas on what it could be...or how to figure out where the disconnect is?
If you are talking about the front corner amber lights next to the head lights, those are NOT running lights, they are turn signals only.
Your running lights are inside the headlight housing, they are called "city lights", there is a separate bulb that comes on when you have the running lights on but not the headlights.
If they do not come on your "city" bulb is burnt out.
As for the side markers in the front bumper, corroded wiring, the bulbs are exposed to road grim and stuff.
Thought the same thing when we got ours. Like Spike said the lenses by the headlamps are only signals. As for the markers in the bumper, ours were burnt out as well. We had to install new sockets and bulbs and that solved the problem. Make sure the o ring on the bulb socket is intact as well. They like to dry rot and fall off which lets in a ton of water.
Spike - I may have misunderstood one of your previous posts. You mentioned some marker lights in the bumper. Since i don't have a bumper (and these lights don't exist) they don't come on.
Do these marker lights in the bumper illuminate when the rest of the "parking lights" are turned on?
BE CAREFUL WHEN MISSING WITH THE LITTLE LIGHTS IN THE BUMPER. I hooked mine up and suddenly blew 3 fuses! I didn't have any interior lights, and no tail lights. Just headlights. It scared the hell out of me, thinking I created a monster. I believe it was two 10 amp and one 20 amp fuse. I know they were both in the drivers side foot well. I would check fuses first, and if you must have them, then consider yourself playing with dynamite when it comes to hooking these ups.
