Front propshaft
Old Dec 4, 2012 | 06:02 AM
  #41
Thivanka Jude's Avatar
4th Gear
hey guys i have a question, if you remove the prop shaft will the ird unit n vcu creat problems ...cause i hear that the vcu unit's liquid thickens and causes the ird unit to fail and then give problems to your diff ...i just want to knw if we remove the prop shaft and turn it in to 2wd can i prevent the above problems from occurring? pls help :\
thank you for your help
Old Dec 4, 2012 | 07:45 AM
  #42
IRD - which Rover do you refer to?
Old Dec 4, 2012 | 08:21 AM
  #43
4th Gear
well im new to the land rover field this is my first purchase ..its a 1999 freelander diesel 2.0
Old Dec 4, 2012 | 09:32 AM
  #44
While the Freelanders have their own area on the forum, and their own set of problems, the front propshaft issue here seems to be focused on the D2, which had this end on the front shaft with no grease fittings.
Old Dec 5, 2012 | 07:17 AM
  #45
Disco28's Avatar
Reading through the posts here and I was wonder is someon could post contact information on the companies that rebuild the driveshafts. I have some vibrations coming from the front that I am diagnosing. If I need to rebuild a DS the information would come in handy.
Old Dec 5, 2012 | 07:29 AM
  #46
antichrist's Avatar
Yellow pages already publish lists.
Driveline shops.
coors
Feb 22, 2011 11:28 PM
Robover01
Nov 19, 2009 08:25 PM
bradbenz
Oct 24, 2009 08:53 AM
tgray
Freelander
Jul 6, 2009 02:30 AM
knuklebuster
Dec 11, 2008 10:41 AM
