Front PropShaft Clunking
Old Feb 22, 2011 | 08:01 PM
coors's Avatar
Default Front PropShaft Clunking
Help me determine the cause of my front propshaft clunking syndrome. I do not have a new or rebuilt propshaft w/ greasable joints. I know...replace it w/ serviceable grease fittings. My U-joints look and feel solid (no visual sign of wear). I pumped grease into my front and only U-joint grease fitting, still no cure. I am ruling it out, please move on.
I had the trans in neutral, wheels chocked, and am able to turn the shaft (between the transfer case and front diff) 5 degrees or so in either direction. So, to me it seems there is wear in both the transfer case and front diff?? If this is true, HOW? The truck has not been a victim of abuse (i.e. rocking the truck back and forth...shifting from drive to reverse, and I haven't towed anything). This is a new event.
I can recreate the clunking when lifting off the accelerator and again when depressing the accelerator. What gives?
Or maybe, it is my U-Joints?
Old Feb 22, 2011 | 08:09 PM
antichrist's Avatar
Sounds like you know all about u-joints, so I'll move on.
Old Feb 22, 2011 | 08:24 PM
LundRover's Avatar
Lol
How many miles do you have?
Old Feb 22, 2011 | 11:28 PM
mwindth's Avatar
Originally Posted by coors
Help me determine the cause of my front propshaft clunking syndrome. I do not have a new or rebuilt propshaft w/ greasable joints. I know...replace it w/ serviceable grease fittings...I can recreate the clunking when lifting off the accelerator and again when depressing the accelerator. What gives?
Coors...what you are describing is drive line slack and it is normal for our trucks. But, please replace your front drive shaft w/greaseable u-joints immediately or the next "clunking" you hear will not be drive line slack but the front drive shaft "clunking" a hole in your transmission, seriously.
erkangenel
Sep 21, 2022 05:15 PM
Robover01
Nov 19, 2009 08:25 PM
bradbenz
Oct 24, 2009 08:53 AM
tgray
Freelander
Jul 6, 2009 02:30 AM
knuklebuster
Dec 11, 2008 10:41 AM
