Front timing cover
Old 06-01-2015, 03:59 PM
sumeet's Avatar
Default Front timing cover
Should I place the new gasket onto the block, then bead Ultra Blue gasket maker onto the gasket itself?
After that how should I oil up the timing chain and "oil pump"? While I was using carb cleaner to clean surfaces, I got some on the timing chain. Not very much at all, but I am just wondering if I should oil it up.
Next, I imagine that I could follow Rave manual for front cover tightening instructions.
Detailed (dumbed down) advice would be kindly received.
I've got a smart phone, if pics are needed
Old 06-01-2015, 05:24 PM
TOM R's Avatar
Thin bead of rtV ultra black on gasket
Pack the oil pump with vasoline,
Pull plugs and fuel pump fuse crank engine 20 seconds at a time? Till oil light goes out
Reinstall plugs and pump fuse , timing chain will get lubed or just put oil on it
Old 06-01-2015, 05:54 PM
antichrist's Avatar
Originally Posted by TOM R
Pack the oil pump with gasoline,
WTF?!
Pack the pump with a thick lubricant. I use Lubriplate No. 105 Motor Assembly Grease.
You can smear a bit on the timing chain and you'll be fine.
Old 06-01-2015, 06:31 PM
ihscouts's Avatar
ROTFLMAO!!!!!!!!
Thin bead of TV packed with gasoline........ The phone's auto complete likes old Knight Rider TV shows, won't let Tom intervene.
Old 06-01-2015, 07:39 PM
TOM R's Avatar
Aaaaaaaaaaahhhhhhhhhh f ing auto correct
Rtv
Pack with vasoline
This is dumb tablet has poor dictionary, my phone was so bad wife turned down the correct/complete feature
Old 06-01-2015, 07:54 PM
sumeet's Avatar
Default Thanks
Ok. I'll hit up lordco tonight and get VASOLINE (lol) and the black gasket stuff. I've got the heads off, because this began as a head gasket job. I'll figure out the plugs thing later, as I rebuild up that way.
I'll post as things progress. Keep the tips coming guys.
Old 06-01-2015, 07:55 PM
ihscouts's Avatar
It keeps me laughing my **** off, don't change anything!
Old 06-01-2015, 08:00 PM
sumeet's Avatar
Default Just remembered
I just remembered that I bought Lubriplate 105 a couple weeks back. I'll just use that. So can I use that Permate Ultra Blue multipurpose gasket maker for anything on this rebuild project? For example, can I use it when I replace the oil pan? Or should I stick to the black rtv?
Old 06-01-2015, 09:06 PM
TOM R's Avatar
I never use blue so no idea, plugs is spark plugs, I used right stuff on oil pan
Old 06-01-2015, 11:01 PM
loanrangie's Avatar
Originally Posted by antichrist
WTF?!
Vaseline works fine, done it a few times myself when rebuilt engine wouldnt prime the pump.
Mind you this was in 3.5's with the external pump not the 3.9/4.0 crank driven pump.
Quick Reply: Front timing cover
