front washer pump
Old Nov 28, 2020 | 03:32 PM
jimvw57's Avatar
Default front washer pump
Windshield washers don't work, I am guessing it is a pump, fuse checks OK.... having trouble getting the reservoir out from under the hood. I am guessing at 2 bolts/studs that go down into the wheel well, but they just turn and don't let the nuts turn. I doubt I should put too much stress on them or just rip out the tank.. I got the 2 bolts on the top edge out but it still won't move (much) Any thoughts?? Might need the washers this winter I am guessing.
No leaks, just doesn't pump (front or back)
Old Dec 2, 2020 | 10:33 AM
vegas99d1's Avatar
You'll need to cut those bolts off that are in the fender well. I've had to replace the washer pumps on my D1 a couple of times now. Hit up Will Tillery for used ones at a good price.
Old Dec 2, 2020 | 11:09 PM
jimvw57's Avatar
guessing on using a grinder as a torch may melt the bottle. I do have a spare on my other truck, just need a bit of warmer weather outside hopefully it is the pump and not some crazy wiring stuff.. Might just run a wire out to it and put a button on the dash!
Old Dec 3, 2020 | 10:36 PM
vegas99d1's Avatar
i used a dremel cut off wheel on mine...
Old Dec 8, 2020 | 08:16 PM
reboot's Avatar
had to replace all 3 of mine, front, back and headlights. Got them off Ebay, but one was worse than the one I had. Between the two (front windshield) I made a good one.
Old Dec 8, 2020 | 08:43 PM
jimvw57's Avatar
I know the one on my '97 works so i am sure I have something that will work, just got to put it on the right truck!
sprale
Apr 24, 2017 11:08 PM
sayeedA
Apr 17, 2017 06:52 PM
ertw67
Jul 7, 2012 10:24 AM
ih102
May 21, 2012 01:51 PM
73S3IP
Feb 1, 2009 10:55 PM
