windshield washer does not come on
Old Mar 24, 2017 | 09:10 PM
sayeedA's Avatar
Default windshield washer does not come on
Just noticed the windshield washer does not work- I hardly use Bummer!
Noticed the tank was empty. Poured some washer some of them leaked out not all just little bit. Assuming there is a leak. But the motor is not kicking!
Any idea where to start? Looks like its a lot of work just to get to the tank.
will appreciate suggestions
Thanks
Old Mar 24, 2017 | 09:24 PM
OverRover's Avatar
You could have a dead pump, but first check if Fuse #19 (15 amp) is blown in the Interior Main Fuse Box.
I could be wrong on this one, but also check Relay R7 in the under the hood fuse box.
Old Mar 24, 2017 | 10:37 PM
Bom2oo2's Avatar
If checking fuses as suggested didn't fix problem & you want to get to washer pump, not very hard, remove the plastic under the driver side fender, the one connected to bumper, only few screws holding it, then you will have access to bottom of washer tank & pump, it could also be loose wire connection to pump itself, easy to check or replace pump after plastic piece is out,
Old Mar 25, 2017 | 12:57 PM
Friday Night Disco's Avatar
Just a thought...if you have a bad motor and the tank is leaking, go with a new tank and motor but, go with a smaller version of the tank in case you go with a after market bumper in the future
Old Mar 29, 2017 | 11:07 PM
sayeedA's Avatar
Thank you for all the suggestions. I have not been able to get to the Truck yet. hopefully this week I will tackle this.
I will keep you all posted once I fix my issue.
Thanks
Old Apr 9, 2017 | 11:16 AM
sayeedA's Avatar
Default Finally got some time to looking into
Update - if this helps anyone.
I think I found the leaking source. One of the Screws fell off and the tank is tilted. Can't believe this heavy water filled tank was held by two screws - Engineering screw up.
The long neck came off the tank. I wonder if this just pops in or broken off. my guess is popped out.
Now hunt for the electric issue.
I noticed my wiper motor seriously lags after turning on, sometimes i would have to wait for 10-20 sec (guess) before the wipers start.
Thanks
Old Apr 11, 2017 | 09:51 PM
Mando's Avatar
Default I hear my wiper pump but no water
When I press the lever for water it makes sound but no water comes out and the tank is full. Any ideas?
Old Apr 12, 2017 | 01:02 AM
sayeedA's Avatar
i went all out. took everything off. started from the base cleaned the tank there were some craps in the tank. took out and tested both front and rear motors with water works good, Fuses were ok. took out the relay cleaned the contacts. Cleaned with Air compressor. i narrowed down to the hoses, most likely the spray tip clogged. almost done
Old Apr 15, 2017 | 05:22 PM
sayeedA's Avatar
I cleaned up the hoses have not tried yet.
I found this strange looking connector with the passenger side washer tip. looks like a "non return valve" but does not seem like air pass through. I am guessing the valve is for the washer to always have water close to the tip - may be?
Thanks for your help
Attached Thumbnails windshield washer does not come on-img_6342.jpg   windshield washer does not come on-img_6343.jpg
Old Apr 15, 2017 | 10:58 PM
JUKE179r's Avatar
It's a mini check valve to keep washer fluid in the lines. I noticed that on my Disco too.
If you take a small scribe or paper clip you can push on the ball to unseat it and feel the resistance of the inner spring.
