Front Windows Roll Down By Themselves
Hello all,
So for some reason while im driving my 1997 D1 both the front windows will roll down by themselves, its very sporadic sometimes it happens every mile and sometimes it will go a few trips and it only happens when the vehicle is on.
anyone have any idea????
Also I dont have a key fob and I dont even know if it came with one.
Thanks, Langley
Thanks, Langley
That would be called a "Feature" it senses when you are in the mood for some fresh air....
(had to say that)
probably either a solder crack in the window ECU or a bad window switch.. I have always found problems with the ECU board, easy fix if you are used to soldering boards. Plenty of youtube videos on fixing these boards
(had to say that)
The following 3 users liked this post by jimvw57:
(had to say that)
(had to say that)
Highline-Autos.com
Range Rover L405 (Fourth Gen)
10-06-2021 08:29 AM
