Front Windows Roll Down By Themselves
Old Oct 23, 2021 | 09:13 AM
Biglangster's Avatar
5th Gear
Default Front Windows Roll Down By Themselves
Hello all,
So for some reason while im driving my 1997 D1 both the front windows will roll down by themselves, its very sporadic sometimes it happens every mile and sometimes it will go a few trips and it only happens when the vehicle is on.
anyone have any idea????
Also I dont have a key fob and I dont even know if it came with one.
Thanks, Langley
Old Oct 23, 2021 | 11:40 AM
jimvw57's Avatar
That would be called a "Feature" it senses when you are in the mood for some fresh air....
(had to say that)
probably either a solder crack in the window ECU or a bad window switch.. I have always found problems with the ECU board, easy fix if you are used to soldering boards. Plenty of youtube videos on fixing these boards
Old Jan 4, 2022 | 08:44 AM
5th Gear
(had to say that)
Thanks for the info! It ended up being a cold solder joint, I re-soldered and it works great!
Highline-Autos.com
Range Rover L405 (Fourth Gen)
Oct 6, 2021 08:29 AM
Motorvated
Aug 16, 2013 10:30 PM
bcbp
Feb 3, 2013 04:40 PM
lgerhardt
Jul 8, 2008 10:01 PM
handsome rob
Apr 18, 2007 07:28 PM
