Hi all, I’m looking to replace Fuel injection feed pipe in the picture attached. Anyone has any idea where to find it or perhaps another generic feed pipe that matches?
Thanks
Good luck with your search. Local wrecking yard is a good bet. Small technicality, that is not the feed pipe, rather it is the fuel return from the fuel pressure regulator back to the tank. The line below it is the feed to the fuel rail. Emergency alternative is to cut the ends off and splice in a rubber fuel hose. My older version Discos have a rubber hose in that spot, and use slip on connections vs threaded.
Thanks for the clarification. When it comes to Houston area, I’m not sure if it’s me or what but there aren’t yunk yards with D1s. These trucks are unicorns in the land of F150! No complain F150 rock but it’s so hard to even spot a D1 or even D2 around here. Thanks for the slip on hose idea, I’ll keep it in mind in case I can’t find the piece. I was think of trying to straighten the line out as (it is not broken) with some heat and careful manipulation but not sure that’s a good idea, I’m doing head gaskets so line will be oof the manifold, now that you clarified this is the return line i feel more comfortable fixing it tbh
you can also make the line from that Copper nickel alloy piping w/ some flare and bend tools. Not hard at all - just takes some practice but Ive done it on other vehicles.
