Fuel level sensor.
Old Oct 13, 2012 | 03:16 PM
Michael M. Koch's Avatar
Question Fuel level sensor.
Here's my strange problem: I fill the tank, fuel gauge never goes above 3/4, but otherwise seems to work. (Gauge goes down as the vehicle is driven.) Ultra Gauge fuel menu gives me an error along the lines of "fuel sensor not found." If that's the case, as in the sensor doesn't work at all, why does the factory fuel gauge work, sort of?
A little more info: Gas tank appears to be original, but the two hoses running to the filler cap have been replaced. (The truck was in an accident back there at one time, minor body damage.)
Old Oct 13, 2012 | 06:19 PM
Could be the tank is smushed and has a dent in it making it smaller.
Could be a bad float.
Could be a bad sending unit.
Old Oct 13, 2012 | 06:56 PM
It is possible to replace the float or sending unit without replacing the tank, assuming it isn't smushed?
Old Oct 13, 2012 | 09:12 PM
bcbp's Avatar
I'm not sure if this helps, my dash fuel gauge works fine however my ultra gauge says the same thing as yours and also has some bizarre mpg reading.
Old Oct 13, 2012 | 09:49 PM
No you cannot just replace the sending unit, yes you could replace just the float if you could get a different one.
Old Oct 13, 2012 | 11:45 PM
wheelgarage's Avatar
The sending unit does go bad....I know, it happened to me.
Odd that is shows an error thou...
Old Oct 14, 2012 | 12:19 AM
Ultra Gauge can't "see" the fuel sender, it does not report to OBDII port on a D1, so that is why "sensor not found." UG is generic for all OBDII vehicles, so there will be sensors that Disco does not have. As for the mpg, you'll have to move the decimal point.
Old Oct 14, 2012 | 11:32 AM
dansgt's Avatar
mine does the same thing. new pump assembly and tank changed nothing. I think my needle just sits too low.
Old Oct 14, 2012 | 11:38 AM
Thanks all for the info!
Old Oct 14, 2012 | 10:21 PM
tooltech's Avatar
Most times my fuel low light is on.. I always make sure I have enough gas before going way out there, like today.
Michael, this is where I went today- Google Maps
Slow jeeps kept getting in my way though.. grrrr!
